I've cut open a 1042 filter and the element really is tiny. I've gone up to the 52 filter which has an additional inch of filter material.
That said, if you are using this for a track car, you are changing oil so often, if you also change the filter, the small napa filter will be a non issue. I'd run that instead of the mega buck washable one.
Also, I really don't think the accusump is worth the trouble and complexity.
