Originally Posted by KevinH1990
I know the 986 and 987 hard tops are different, but I don't know whether the same is true for the attachment systems.
I fitted the hard top to my 986. While it was tricky for me, I don't think a good mechanic would have much difficulty if they had access to the instructions. To be honest the instructions I found for the 986 top on Renntech were superior to the Porsche service bulletin.
Perhaps you could ask the dealership for a copy of the service bulletin for the installation of the 987 top. If they don't have it, it might indicate that they are trying to figure it out as they go along.
Good luck.
Actually, I'm a contributing member at Renntech forums and look at all the TSB's. Some of them I've seen before they do if they reference European cars, for instance.
The TSB you refer to is dated 1-13-05 #6117 as I'm looking at it now.
I see they were able to install the locking pin receivers on the body (real slick and unobtrusive, I like that very much) and they are installed on the correct side. What I'm told is that they are unable to get the pins that come down through the top into these receivers to lock completely. They are supposed to turn 1/4 turn and engage the receivers.
They are in communication with Porsche in Germany. I took the car back (without hardtop installed) and I'll be in contact with them first thing Monday morning......
