I think a bigger issue other than brand is that you are going to put a totally different tire on the rear that is new, vs an old different tire on the front. 4yrs is getting close to “old” in terms of rubber and I’m not so sure putting new with old is the best option. Boxsters do eat rear tires, but there is a point where the whole set needs to be done. Where you are with tire age, I’d put the Federals all the way around most likely.
