Old 09-16-2006, 09:53 AM   #20
Gary Gaukler
One other thought: You said it stumbles at idle for a while, and then it goes away. That could be another indicator that your fueling is off. The first couple of seconds at idle the car is in open loop: the o2 sensors won't correct the A/F ratio until they have warmed up. Hence you are running off some standard fuel maps. Once the car is idleing in closed loop, the o2 sensors correct the mixture.
Gary Gaukler is offline   Reply With Quote
