Old 09-09-2018, 06:28 PM   #10
speedyspaghetti
I've done front and rear. Fronts were easier due to not having to screw with the parking brake mechanism.
I didn't use the SIR tool but simply removed the hub and pressed out the bearing. Even if you have a shop R/R the bearing from the hub, it'll be cheaper than buying the SIR tool. Not dissing the tool...you could buy it, use it and sell it on if you want.
Remember to buy new axle nuts!
Is the axle nut torque the same for both? What tool did you use to press out the bearing?
speedyspaghetti is offline   Reply With Quote
