Thread: Window switches
Old 09-09-2018, 11:56 AM   #11
Bruich10
Originally Posted by dsallean View Post
My driver's window has decided to stop working. It doesn't drop when I open the door with either inside or outside handle. I checked the fuse for good measure and no problem there. I swapped out the center console switches and the problem stayed with the driver's window. Trying the key in the door doesn't lower the window either. It's a real pain to open and close the door when the window doesn't drop!
From searching it appears the door latch or microswitch might be the problem. Any way of knowing which part is at fault so I can get something on order to fix it?
Had the same this spring. Drives you mad.....
My experience is that you need to replace the entire window mechanism in the door.
Not the world in cost but a bit fiddly apparently.
I am not the greatest mechanic so I had it done at an independent, but Porsche approved, garage. They say they do tons of them on 986 and 996 these days. Especially the passenger side for some reason.
2003 Boxster S
Seal Grey
Bruich10 is offline   Reply With Quote
