I am still having the same problem. Seems intermittent with regards to the window dropping and I'm not too sure either which switch is causing it. My passenger window only moves about an inch each time I press the centre console switch and have to keep pressing it to make the window go up or down. It seems like the distance that it moves is about the same as it should drop when opening the door or engaging the convertible roof. I am thinking to pull the door panel this week and see if it's a loose connection or something simple
