Thread: Window switches
Old 09-09-2018, 07:35 AM   #8
dsallean
My driver's window has decided to stop working. It doesn't drop when I open the door with either inside or outside handle. I checked the fuse for good measure and no problem there. I swapped out the center console switches and the problem stayed with the driver's window. Trying the key in the door doesn't lower the window either. It's a real pain to open and close the door when the window doesn't drop!
From searching it appears the door latch or microswitch might be the problem. Any way of knowing which part is at fault so I can get something on order to fix it?
dsallean is offline   Reply With Quote
