Old 09-05-2018, 12:17 PM   #20
PaulE
Originally Posted by robdelorenzo View Post
I do have an 02 base, but I think the concept is the same.
This must be the part that is referred to as "needing a putty knife to gently remove"
that I saw in one of the posts.
I ordered them anyway and want to do the job right and completely replace all components.
For some strange reason, I am looking forward to the Aerokroil.
That stuff looks like fun!
Yes if you're replacing the front pads on an S you need to insert the putty knife between the backing plate of the brake pad and the thin plate holding the 2 dampers together. When I did my front brake pads, I followed the online information for non S cars and didn't know about these dampers. They were never on the old British cars with Girling or Dunlop disk brakes that I worked on as a kid, so I thought the pads would just come out after I took out the retaining pins. Since I was also changing the rotors, I removed the calipers which I had to do anyway so I could see what was going on in there.
