An even better fix is to pull on the plunger on the switch. If you pull it all the way out it will adjust to the correct length the first time you release the brake pedal.
Push the brake pedal down, pull on the plunger and it will come out and you will feel the ratchet. Release the brake pedal and you are good. Do the same with the clutch pedal for good measure!
1941 Dodge Luxury Liner Coupe
