Thread: PS Line Replace
Old 09-03-2018, 07:48 PM   #19
maytag
Who's askin'?
maytag's Avatar
Maytag, since the rack is full of gunk I am guessing the oil rings to be the culprit
If your car is drivable clean everything up, :-) and you should be able to see where the leak is originating.
Not sure I understood you well (sorry), are you suspecting that the leak is coming from the rear side of the fitting, at the end of the rubber hose..? That is sipping alright but not enough to create the mess at the rack anyway (IMHO).
But once you wash it, we'll see for sure
Thanks Gilles, I appreciate your thoughtful attention. However, I don't need to clean it to find the leak, it's quite evident, haha.
And yes, it leaks at the plastic (it's not rubber) hose where it goes into the fitting. Not from the connection point of the fitting. Both ends are leaking this way. Have you seen this before? Odd to me, as this is supposed to be the low-side, return. Should be very low pressure. Right?
