Old 09-15-2006, 02:25 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
When i got my MAS code on the Scanner, it was accurate, However i do not think the misfire is related to the MAS code, I think maybe that misfire could have been a result of your boost leak you had OR maybe the mixture is getting too hot and your getting detonation and in that case i would recommend a colder spark plug...denso iriduims are awesome and autozone usually keeps them in stock.
If you pulling an o2 sensor code i think they were just about on there way out and the added heat exhaust gases from the supercharger may have helped in them failing. You may need all 3 things replaced.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
