Attached below is the emissions testing requirements for the State of Ohio. Yours is one of the 7 most stringent Counties (Cayahoga) and appears to require a Dyno test.  You can read and research what is required to import a car from out of State. While this car may pass an OBDII test, it will fail a visual test since the rear cats have been removed and replaced by test pipes, then you would be required to repair the car to pass smog. Could be a headache depending on how aggressive or not your chosen smog test station is.
https://www.dmv.com/oh/ohio/emissions-testing
