Old 08-27-2018, 04:30 PM   #33
bagpiperse
Hi all,
So I could use some further guidance.
The secondary air pump is not receiving power at startup, and thus not running on startup.
I checked the pump itself and it runs off of battery power.
I checked the 40a maxifuse and it has conductivity.
I checked the connectivity from the relay to the connector at the pump and there is connectivity.
I replaced the relay.
I replaced the air intake (manifold) temperature sensor.
The pump still isn't getting power at startup.
Some have mentioned the ECU.
I have assumed that the coolant temperature sensor is not the problem, as the gauge on the dash seems to work fine. Please let me know if my assumption could be wrong. If not,
Is the only thing left to consider the ECU?
Thanks.
Scott
bagpiperse is offline   Reply With Quote
