Old 08-26-2018, 01:14 PM   #4
mikefocke
Why do you need a mechanic to clean the drains? Are you sure that is where the dampness is coming from?
As far as diagnosing the water leak problem, fill a quart jar with water and put a pan on the ground just forward of each rear wheel to catch the water as you pour it down each drain hole. The drains exit just forward of the rear wheels. If you have a full quart after it all drains out, your problem lies elsewhere than a clogged drain. Be sure to check each foam liner drain tray for any rips or tears, especially in the area directly beneath the V-levers that operate the pushrods of the convertible top. If you ever had one of those pushrods break and the V-lever rotated with the broken pushrod dangling, it will invariably cause a tear in the drain tray that will in turn cause water to leak into the passenger compartment.
You can buy the drain trays separate from Porsche.
Porsche calls them "water drip pan" .
The part numbers are as follows:
986 561 805 03 (Left side)
986 561 806 03 (Right side).
They each list for $75.76, but you should be able to get them for less from Sunset Imports.
Replacement is straightforward but a little time consuming. The most involved part is the removal of the three bolts (and either one or two phillips head screws) that hold the base of the convertible top frame onto the car. You will also have to remove the 19mm bolt that holds the V-lever onto the convertible top transmission,
