Old 08-26-2018, 10:57 AM   #2
A8ked
A8ked's Avatar
I'd suspect the roof switch next. If you're lucky you may just have a poor contact at the plug or in the switch. Try unplugging the connector on the back of the switch and then reconnect it. If you have a volt meter you could also test the switch for continunity when pressed.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
