Old 05-07-2004, 02:00 PM   #2
Rouser
Rouser's Avatar
This might sound WAY stupid, but you better check tire pressures all around, and make sure they're up-to-spec. Also, what are these? 16"/17"/18" rims/tires?
Some owners seem to think that when it says "Maximum tire pressure: 35 PSI" on the sidewall, that THAT'S what the pressure is suppose to be set to. Maybe the seller pumped them up after spraying the tire sheen, and you're just dealing with a skitish 986.
It's a '00; let's look at the simple before writing off the suspension.
Rouser!
Rouser is offline   Reply With Quote
