Old 08-24-2018, 05:29 AM   #12
bagpiperse
Thanks for those replies.
So, I think I left out some information. The secondary air pump is not coming on at cold start-up. It does work, as verified by giving it power directly from the battery.
I have checked the fuse and put a new relay in, and checked the wiring from the relay to the pump.
Thanks for the information regarding how the system works. I don't know where the engine temp sensor is to check it. I did some searching around on the internet, but didn't find anything saying where the sensor is or how to check it.
I don't know where the ECU is either, or how to check if it is sending the signal to the relay. Thanks again.
bagpiperse is offline   Reply With Quote
