Old 08-21-2018, 04:21 AM   #1
walterlh
My fabricator charged me for 3 hours labor. He said the most amount of time was cutting and fitting the pipes to the exhaust tips. I have double walled removable tips and I wanted them to remain removable after the mod. He had to slot them toward the rear so they would slip on and off. It took a lot of careful grinding work to do it. Otherwise you could just drill a hole in the side of the tip and tack weld the pipe to it like many have done. I used this:Stainless Steel 304L Welded Round Tubing, 1-1/2 OD, 1.37" ID, 0.065" Wall. Get the 304L for best weld stainless to stainless.
walterlh is offline   Reply With Quote
