Old 08-20-2018, 04:56 PM   #13
particlewave
I've rewired them, but always take them apart to do so.
The turn and fog light wires are zip tied together, so you could cut them near the headlight connector, then use the fog light wires to pull them through the fog light bulb access hole. Cut the wires there, leaving enough turn signal wire to work with, and just slide heat shrink tubing down the remaining turn signal wire and replace the rest.
