Old 08-20-2018, 10:36 AM   #23
AZ986S
AZ986S's Avatar
Originally Posted by Calmg0d View Post
This past weekend I swapped out both rear wheel bearings. It was a time consuming effort but really not that difficult as long as you have the CORRECT bearings. Thanks to Scott at PelicanParts.com I was able to get the correct bearings AFTER ordering the others from another online discount parts retailer.
The S has different wheel bearings for front and rear. If you look at most of the online retailers they will not show a difference for the front or rears even when designating the S model.
Since I had the hub all disassembled I swapped out new parking brake shoes too. However, now I have the shoes rubbing even after adjusting them twice according to th Bentley manual.
Does anyone have any idea how long that rubbing will last?
Thom
I had a similar problem after having the shoe stick to the drum after a hot session and pulling parking brake. Was able to unstick pretty easily, but ended up having to loosen up the adjustment a couple of times because it would grind in aggressive turns. Too loose or too tight is not good.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
