Old 08-18-2018, 06:40 PM   #10
particlewave
Actually, what I said...
START by calculating and installing the appropriate fuse size for the stereo, as I suggested (if the 15 amp fuse wasn't already adequate). If that blows, then you have a problem.
There is no sense in searching for a short until you're sure you have one.
Originally Posted by rexcramer View Post
As thstone has pointed out, you are developing a short somewhere. The point of the fuse is to prevent an electrical fire. If you continue upping the size of the fuse, you get to a point that is referred to as a 'smoke test'. It will be obvious where the short is. It will be where the smoke and or fire is coming from. I suggest that there is a wire that has been chaffing against something that is getting progressively worse over time. Wires are usually bundled together and you risk melting adjacent wires with a larger fuse. Thus creating additional electrical problems. Start looking at wires coming through the firewall/bulkhead.
