Thread: winter project
Old 08-17-2018, 05:32 PM   #33
maytag
Who's askin'?
maytag's Avatar
so far my winter project was going great, and didn't have any special issues, except the broken bolts that was easy to remove.
but then i got to the RMS.
man, just looking back at it makes me furious again.
i thought that will be the easy part, especially after completing the IMSB under an hour.
i was wrong.
first i had hard time removing it. the technique with the screw and pliers didn't work well, i ended up filing on of my prey bars to fit and the screw head, and used a piece of wood as a pivot.
i highly recommend using one of these to make it easy on you:
SG Tool Aid 81500 Junior Slugger Slide Hammer Dent Puller : Amazon.com : Automotive
putting the new one was even worst.
i have to admit i was not mentally prepared for the job.
i was sure it will go easy, so i pounded it with a hammer using a 3" PVC tube.
the RMS went in crooked.
that was the end of the day for me. i found myself on Saturday 12PM, with nothing to do.
i was hoping the finis the car that weekend.
was so frustrated since i work on the cars during weekends, and now i wasted half of Saturday, and all of Sunday.
Monday morning i made my firs encounter with my local dealership. paid 24$ for the RMS, and realized why they are called stillerships.
Tuesday was a day off, so i gave it another try. i messed it up again.
you really need patience with that thing.(which i don't have)
for the first time i gave up. started searching the web for the SIR RMS tool, with no success.
placed an order for new seal and some other parts i needed, and waited for the following weekend.
when i got the new seal, i meditated for half an hour, and promised myself to take the time and not to get upset.
i started pounding on it real slow with very light taps over the seal, with a piece of flat plastic bar. every time i started loosing my patience, i walked away, smoked a sig, drank some cold water, and got back. the most difficult part is to drive the seal up to the point where is flush with the case.
then i took the PVC pipe and drove it to the correct depth.
the whole thing took me over an hour
next time, i get the tool
i would like to take this opportunity to thank Heiko and Hal (AKA whipE350) for the support and the good advise.
This. So much this.
Here it is, first part of friday evening, and I'm broke down cuz I destroyed the RMS trying to install it.
So frustrated. My machinist finished my flywheel, so I'm ready..... just to be foiled by the RMS.
Do any of you have any tips for the installation? I went and bought the abs pipe to drive it, but I cannot get it to go in straight. No matter what I do. Tried it a dozen times before I finally decided the new seal was no longer useable. Then I tried it a dozen more to see if I could devise a technique for the next one.... didn't work. I'm so frustrated with this right now.
Any help is appreciated.
