It's an easy test and may find your problem, or one you have and didn't know you had.
Get yourself a can of starting fluid and and with the engine idling, (carefully, it's flammable) spray small amounts of ether around the AOS hoses and intake manifold. If you get a change in the RPM (an increase) you've found a vacuum leak. Electrical tape is your friend while you wait to do the fix.
Woody gave me this suggestion on a problem of misfiring at high rpm that both the local P dealer and Indy shop wanted $800 to diagnose after paying them $160 each to get an estimate. (sorry guys, I'm not that stupid). Save your money and get the ether.
Good luck. It's definitely an enthusiast's car, and it helps the wallet if you can do a bit of wrenching.
'98 986 Arctic Silver
Reason: correction to statement
