Old 08-14-2018, 12:43 PM   #1
particlewave
The black wire to any good ground (there should be a ground bolt right by the fuse panel) and the red wire to any switched fuse using a fuse tap (switched fuse would make it so that it only came on with ignition on).
I'll look at the fuses and find a good one later tonight.
