Old 08-09-2018, 01:26 PM   #15
maytag
Who's askin'?
maytag's Avatar
Have you scanned the DME for stage 2 over revs? Might show something. I saw something similar where an individual thought it was a good idea to leave the trans in first gear while coasting down a hill with the clutch depressed. Can't even imagine the RPM that clutch disk saw before exploding.
Thanks Monty. There are plenty of over-revs stored in the DME. And heck, I'm guilty of some of them myself, at the track. But a simple over-rev of the motor (what the DME is recording) shouldn't cause this sort of failure. What you are describing, (coasting down the hill with the clutch depressed )wouldn't have registered at all in the DME.
But you got me thinking:
I did this at the end of the front straight at UMC (Outer Loop). I only got two laps before this happened, but in those two laps, I was hitting 121mph on the straight, then braking to around 85mph as I start to turn-in at turn one, but continuing to brake down to about 60mph at the apex. When I went for the brakes and depressed the clutch simultaneously, then tried to go for 3rd gear, it wouldn't go in. I tried again; wouldn't go. So I took my foot off the clutch to coast through the corner, but the pedal didn't come up.
SO: I can only guess at what speed I tried to grab 3rd gear, because I was braking aggressively, and I can't see my hands in the HLT video; but I would guess around 90mph. That should not be an issue for 3rd gear (that's about the MPH where I upshifted to 4th. And on a different track configuration, I hold 3rd to 98mph before braking). Yes, I rev-match as a force of habit (I'm a motorcycle-guy, it's truly a habit, haha).
So let's say I was REALLY fast on that particular lap, and hit maybe 130mph (I doubt it). And let's say I was trying to enter turn one much faster than before (possible, as I had some clear track ahead of me, having passed the corvette I had been waiting on previously). Let's say I hypothetically tried to grab 3rd gear REALLY quickly, at 100mph. I really don't know if this is plausible... I don't have enough data. I find it unlikely, but possible. If the synchros engaged and rapidly spun-up the clutch to the RPM's it would need to engage 3rd gear at 100mph, then I would think this sort of failure is, well, possible. I guess. But I would hope the clutch could take that sort of spin-up, should'nt it?
I just found someone on Rennlist who posted these top-speeds for the 6-speed, with stock tire size:
1st=~42 MPH
2nd=~70 MPH
3rd=~102 MPH
4th=~127 MPH
5th=~154 MPH
6th=~190 MPH
seems about right. I just can't fathom me trying to grab 3rd at 100mph should create this sort of catastrophic failure.
I'm ready to learn if any of y'all have a different outlook on it?
