Old 08-08-2018, 07:30 AM   #2
PaulE
Originally Posted by gabedrummin View Post
I also had a 2000 ....3.2 motor that suffered low oil pressure at idle .I was lucky enough to get on of LN Engineering motor through the recent sale terms. I pray I have gotten a good motor as they only supply a 90 day warranty. And most of that was used by the company installing it.After replacing the clutch flywheel & bolts motor mounts expansion tank and all the hoses , gaskets ,Dip stick tube,replacing the cold air kit back to stock air box, belt,Fuel injectors , oil and coolant & flush and the cost of instillation. The cost has passed the 10k mark .
Mine crapped out a couple of weeks after all of the LN sale engines were gone, otherewise I would have gone that route. My shop said that was a great deal and those were the only rebuilt engines they've seen that they trusted (they haven't seen any Flat 6 Innovations engines). You should be good to go when it's finished!
