I also had a 2000 ....3.2 motor that suffered low oil pressure at idle .I was lucky enough to get on of LN Engineering motor through the recent sale terms. I pray I have gotten a good motor as they only supply a 90 day warranty. And most of that was used by the company installing it.After replacing the clutch flywheel & bolts motor mounts expansion tank and all the hoses , gaskets ,Dip stick tube,replacing the cold air kit back to stock air box, belt,Fuel injectors , oil and coolant & flush and the cost of instillation. The cost has passed the 10k mark .
