Old 08-07-2018, 04:45 PM   #4462
Burg Boxster
Originally Posted by A8ked View Post
After nearly getting rear ended by a texting driver this morning.
I finally installed a Brake Light Flasher on my middle brake light this afternoon. I had put one on my other car a year ago, but never got around to installing this one on the Boxster. It's a simple install and I'm glad to have finally done it. Now when I hit the brakes it flashes 3 times quickly and then stays on as long as the break pedal is depressed.
Does it do any good?, well I can't say. But with all the inept drivers (it's an overstatement to refer to them as drivers) on the road, what can it hurt?
Last I check, most states will ticket drivers for a unauthorized use of a flashing red light... whether applied by brake pedal, switch in cabin or even depressing the break pedal you have in your vehicle.
Doubt any such devices are DOT or NHTSA approved... but good luck
"Cool Prius!"
- Nobody
