Old 08-06-2018, 12:37 PM   #10
Seadweller
Originally Posted by rexcramer View Post
After the cluster plugs, I would like to suggest that you check voltage while off and running with a multi-meter and report those numbers.
Where's the best spot to check voltage?
The car has run/operated perfectly normal since the battery replacement, so this just came up out of the blue, which would lead me away from the battery. I would assume (I know, always dangerous) that if there was sufficient voltage to start the car, it should be enough to power the cluster.
1998 Porsche Boxster - Ocean Jade Metallic
1985 Porsche Carrera Targa - Guards Red
1978 Porsche 911SC Euro Non-Sunroof - Grand Prix White
Seadweller is offline   Reply With Quote
