How does your cruise control not work? It may be as simple as the brake or clutch switches being bad or not engaging because of a broken clutch assist spring. If you reach down and up at the clutch pedal you will find a read and black switch that is pushed in when the clutch is released. You can pull the plunger out and then see if it works. You can also try to lift the clutch pedal with your foot while engaging the cruise control. Tell me more and I may be able to help you.
1941 Dodge Luxury Liner Coupe
