Old 08-02-2018, 07:04 AM   #4451
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Originally Posted by Lew View Post
In regards to the Motive Pump. Do you pour Brake fluid in the pump or just use it dry for adding pressure and top off the master cylinder when needed. Also how many pounds do you pressurize the tank? I have the Motive and not real fond of it. I use a vacuum pump to bleed the brakes.
Lew
Lew, I didn't put any fluid in the bleeder itself. I removed old fluid from the reservoir and added new fluid to the very top. I then attached the bleeder and pumped it to 20 psi. I bled the brakes and kept an eye on the reservoir and pressure. Only once in the whole process did I have to relieve the pressure and add fluid when it got down to the MIN mark. In total I used about 3/4 of a litre of fluid.
Clean up was a breeze since the pump does not actually touch the fluid so only the drain lines need to be cleaned. Like I said the whole process was much easier than I thought it would be.
