Old 08-02-2018, 06:16 AM   #4450
Lew
So Blessed!
Lew's Avatar
Originally Posted by paulofto View Post
Did some work on my brake system. Replaced the rubber brake lines with Stoptech stainless steel lines, replaced the pads with new Brembos and flushed the system with fresh fluid using my Motive power bleeder. This is my first time doing work on the brakes and other than a couple of hiccups it all went well. That power bleeder makes fluid changes so easy.
In regards to the Motive Pump. Do you pour Brake fluid in the pump or just use it dry for adding pressure and top off the master cylinder when needed. Also how many pounds do you pressurize the tank? I have the Motive and not real fond of it. I use a vacuum pump to bleed the brakes.
Lew
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
