Thread: RoW Flash Help
Old 08-01-2018, 06:44 AM   #9
The Radium King
The Radium King's Avatar
i'll just post here ...
you will need your dme programming code and your VIN.
go DME - Read-out Vehicle Data. not sure if this is required, but the guru told me to do it so i do it.
go DME - Programming - Program Map. you will be asked for your dme programming code. your VIN should auto-populate - confirm correct.
choose the map you wish to flash onto your car. get the year right or you will get errors due to canbus differences.
you will be given instructions - turn off all accessories, put battery on charger. follow them (if you trust your battery then charger not needed).
flash takes less than 5 minutes.
check for faults. check vehicle data to ensure VIN is good.
