Thread: Trunk Lights
Old 07-31-2018, 07:13 AM   #2
Burg Boxster
I read upon this forum, just recently, that if one end is open, the other end, too, lights up.
That is 100% correct... if either end open the other lights up as well.
So if they don't light up when the front only is open, the issue most likely is the micro-switch in the front latch (common BTW). Same in reverse if rear open but light does not illuminate.
Suggest you try working it w/ some good penetrating oil (Kroil, PB Blaster, etc.) to see if it'll free up first... Otherwise you'll need to remove and check the contacts, wiring etc. Repair / replace as needed from there.
Good luck
"Cool Prius!"
- Nobody
