					Originally Posted by dav9515  isnt there also a post on here about the security light that blinks on the CDR220 causing battery to drain and that you can turn it off in the unit?
 I would suspect the light is off when the faceplate is off and therefore no battery drain?  Does sound like time for a new ignition switch as well.
Now that you mention it, I did notice a blinking light on the CDR220.  I've pulled the D8 fuse and recharged the battery.  Lets hope that does it for now.  Whatever it was, it drained the battery a
lot.  The interior lights wouldn't even illuminate.
Why again would the security light drain the battery so completely?
Gonna see about doing the ignition switch this weekend.
