Old 07-30-2018, 05:25 AM   #3
dav9515
isnt there also a post on here about the security light that blinks on the CDR220 causing battery to drain and that you can turn it off in the unit?
I would suspect the light is off when the faceplate is off and therefore no battery drain? Does sound like time for a new ignition switch as well.
dav9515 is offline   Reply With Quote
