Thanks. What I am gleaning is that the 6 degrees is how far it is out of deviation The number at hot idle is the one to monitor- to determine if the chain ramps should be replaced. It is not the number as it returns to idle. The model I have, when activated just changes the cam settings in one fell swoop. So, the change as it drops in rpm is not the number to monitor.
Knowing this makes the difference between doing the clutch install myself and dropping the engine/or finding an Indy with a good reputation.
"YouTube Certified in Various Specialties"
