Old 07-24-2018, 05:44 PM   #26
mikefocke
If there was debris in the engine enough to get in the IMS, how do you know that it didn't get in the small oil passages in the heads or into things like the crank bearings? How will you measure the IMS bearing hole in the block to make sure it is not scored and is still true? Bearings that fail can wobble.
