Old 07-24-2018, 11:13 AM   #12
Lew
So Blessed!
Lew's Avatar
Originally Posted by since95 View Post
I just did mine on Saturday. Engine out during a full rebuild due to a seized rod bearing. Make sure when you remove the valve covers to use the holding tool on the back side of the camshafts. The cover has the bearing journals for the camshafts integrated, so when you remove the cover the camshafts will get pushed up by the valve springs while the tensioner end is fixed. I was told you can damage the valves or camshaft if you don't hold them during disassembly. If I wasn't told this I would have whipped them off figuring they were just covers.
Out of the car the job wasn't terrible, but getting the engine out took me around 8 hours with a 2 post lift. I did the IMS bearing in the winter, and I can't even imagine how tedious it will be to remove the camshafts, fit the tensioner pads, then reinstall with the engine in the car. I know it can be done, but you will need a ton of patience.
Removing the engine is not a piece of cake my no means, and one better make sure they know how the job of replacing the guides is done.....like you said, you don't just remove the valve covers. I have heard cam shafts have been broken by the super strong valve springs.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
