Old 07-22-2018, 07:31 PM   #22
BoxsterHtownTX
Right high beam went out and the switch cannot turn the knob to Parking lights (stuck). Also when I pull the knob to turn the high beam it goes back inside. When I shake the switch it rattles like there's a broken piece inside. Used multimeter to measure voltage on headlight assembly connectors 2 (ground) and 4 (high beam) there's no voltage reading. Is this a broken switch that cleaning will not fix?
BoxsterHtownTX is offline   Reply With Quote
