Thread: Engine issue
Old 07-22-2018, 07:30 PM   #3
Lew
So Blessed!
Lew's Avatar
Originally Posted by mykelamy View Post
Is there a way to free up a stuck or seized 1998 boxster engine thats been sitting for years. Any way to get Marvels oil inside the spark plug holes, being the cylinders are sideways?
Thank you
Have you tried to use a socket on the crank pulley to see if you can move the crank by hand. Yank the plugs and give it a try. You could squirt some oil in the cylinders and see if you can rotate the engine over and over several times. If you free it up by hand, then I would see if the starter will turn the engine over without the spark plugs. By doing so it should build up some oil pressure thus lubricating engine parts.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
