Originally Posted by rfuerst911sc
For those of you that have owned 914's in the past and are familiar with the website 914world there was a gentleman with a last name of Engman ( now deceased ![Frown](http://www.986forum.com/forums/images/smilies/frown.gif) ) that manufactured what was called " the Engman kit " to help strengthen the tub on 914's . Many called it a clam shell but basically it was a very heavy duty L shaped piece of metal . It was aprox. 1.5 " wide at the top and sat on the horizontal portion of the interior rocker structure . It was aprox. 3 - 4 " deep and that portion went against the vertical portion of the rocker . The L pieces had many holes drilled into them and that's where you welded them to the rockers . The pieces were long enough to go from the door posts at the front to the firewall . It also included a piece that went on the bottom of the firewall .
When all 3 pieces were welded in they provided a big increase in chassis stiffness , I installed one on my GT clone with a 3.0 911 engine and the difference was VERY easy to feel . Now to be fair we also are talking a chassis that was designed and built 40 + years ago . But the principle may apply to the Boxster chassis also .
It would be good to see a conceptual sketch of this if you are so inclined. Might be Boxster viable for those with no cage; performing a comprehensive canyon carver build. I will try and search up the kit.
I must say I am very drawn to 914-6 GTs and would consider building a clone someday. I believe the actual cars had a full cage and fixed roof so stiffness should have not been an issue?
Most feel they are ugly cars but I think they are fantastic looking. If you able to find a car that won't corrode and carry out this mod, one could have a very nice GT clone sans cage and a removable top...
