Job done
And what a PItA!
Had bush pressed at a tire shop. Paid more than I wanted $40, but it was my fifth of sixth stop finding someone that could do it.
Hindsight I prop ably should have just bitten the bullet and removed the two water hoses.
Hardest part by far was getting the top two bolts aligned onto the bracket. I also recommend taking off the bottom bracket studs off instead of just the nuts.
As the day went on, it definitely got harder to squeeze under the car.
Felt like a contortionist
Shop that swapped bush said the one he pulled was fine, but there was actually a third of the rubber missing. Car definitely feels tighter.
Patience is a must if doing this job
