I would like to make one correction; there are four nuts [8mm] retaining the tailights.
If you open your trunk and look far over either left [harder] or right [easier] you will see the above mentioned flat looking washers or retainers.
Unscrew those with your hands, and you should [with light] see the four little nuts holding the tailights in.
There will also be a clip [white buss] which is what holds your bulbs into the tailights.
If you are swapping from the stock amber light's to the white and red. There will be a difference in the light bulb holder, which will nullify a set of lights.
Scott
