It's really easy. Just look for the black plastic caps over the carpet and gently pull back. The carpeted pieces are designed to be moved, because this is how you replace the lamps.
Then its just 2 nuts around the threaded shafts of the tailight. Take them out and the whole thing will slide out of the back of the car. The hardest part is getting some kind of wrench to the outer nut on each one.
