Originally Posted by Geof3
If you buy the 997 shifter new, it will have the tool installed. Just make sure you mark your cables where they are currently when you remove them, and as long as you have no issues now, just put them in the same place in the new shifter and you should be fine.
I bought mine used, and I am not 100% convinced the cables are correct currently—hence the need for the alignment tool.
I'm considering borrowing one and making it into a 3d model and having it 3d printed.
