Old 07-16-2018, 10:25 AM   #1
particlewave
Originally Posted by Vidyashankara View Post
I did this and can confirm that I read 12v on the 30 pin. For the ground, I just touched the black probe to a screw on the car
That's good.
If you get nothing from the fan with a jumper between pin 30 and 87, then you have a wiring issue or the low speed resistor is bad.
(Different relay panel in this picture, just showing which pins to jump)
