Old 07-15-2018, 01:30 PM   #10
Lew
So Blessed!
Lew's Avatar
Originally Posted by mikefocke View Post
And when your state your opinion, please detail on what experience the opinion is based. How many hundreds of each have you installed and thus provided the basis of your opinion.
At least I offered an opinion!
Here is another post Jamesp made:
2003 S 144k miles daily driver, clutch slipping at higher loads. Looks like it's time for a new clutch and flywheel. Anyone have words of wisdom on which clutch and flywheel arrangement to choose? How about any "as long as you have it apart" advice?
A earlier quote I made:
Check out the German made LUK clutch and DM Flywheel. I found the LUK had a 9" disc where the Sach's only had a 8 1/2" disc. That assembly was for the Wife's 05 TDI Beetle. I know that Sach's clutches are in the Boxsters. I might also mention the clutch fingers are a little longer on the LUK's which makes the pedal somewhat softer. The Sach's are shorter which makes for a little stiffer pedal. I plan on using the LUK if I ever need to change. The DMF and Clutch is less than $350 from a company in NC.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
