Old 07-14-2018, 01:47 PM   #1
Caeg
If you're sure the larger rear flap isn't moving, check that the actuator arm hasn't detached (under the dash, just right of dead center).
The flap on the right adjusts between heat and cool. The flap on the left is the front vent diverter, IIRC. The left flap should move when switching between center vents, defrost and/or footwell vents.
Both should be covered (you shouldn't be able to see those holes in the flaps). From the factory, they were covered with foam. A lot of us that did the repair went with duct tape (works great).
Awesome. Thank you for the quick reply too.
Caeg is offline   Reply With Quote
